3rd Gen Durango 2011+ models
DD'12 back up camera tilted down (picture)
Old May 15, 2018 | 03:59 PM
arielbzz's Avatar
arielbzz
Default DD'12 back up camera tilted down (picture)
so i recently purchased a 2012 Dodge Durango crew AWD, and when i went to see it before buying it the back up camera was working correctly. the liftgate was going down as soon as you opened it, so the seller changed both of the struts with new ones. wen i went to get the suv i noticed that the camera was facing down. what can i do to fix this?
Old May 16, 2018 | 08:03 AM
SHO Rod's Avatar
SHO Rod
Start by inspecting the camera to see if it is loose in the housing or loose at the mount. A mount issue could be a relatively easy and inexpensive repair. Loose inside the housing could mean you need to replace the camera, and that might get expensive.
-Rod
