3rd Gen Durango 2011+ models
2013 Dodge Durango Crew acting carzy
Old Aug 8, 2019 | 02:04 PM
koonce0313's Avatar
koonce0313
Default 2013 Dodge Durango Crew acting carzy
Recently, my Durango is acting crazy. Driving down the road (40 mph) and I will hear 2 dings, RPM and Speedo will go all the way down to the left then bounce back up, headlights will blink, multiple lights flash on and off on dash. I did some googling and some said it would be because of a weak battery. New battery installed yesterday and I am still having the same issues.
Any one know of any other causes/solutions? Thanks in Advance
Old Aug 8, 2019 | 05:38 PM
DodgeCares's Avatar
DodgeCares
Hi koonce0313,
We certainly understand why this would be concerning. If you’re not able to determine a solution based on suggestions provided here, we kindly recommend connecting with your local Dodge dealer as they are in the best position to assist. Our team is available via PM if you are in need of any assistance with that process.
Mark
Dodge Social Care Specialist
Old Aug 11, 2019 | 01:15 PM
DDCREW's Avatar
DDCREW
V6 or V8? All recalls up to date including fuel pump relay?
Old Aug 30, 2019 | 09:11 AM
BC Durango's Avatar
BC Durango
Sounds like a serial data or CAN Buss issue. You would need to read the DTCs and see if you have any communications issues. Don't know if a regular scanner can read the body module DTCs or not. Most don't.
Bill
