3rd Gen Durango 2011+ models
Settings being lost
Old Mar 12, 2021 | 10:41 AM
ih560's Avatar
ih560
Changing the setting worked for me and has been fine for the last couple of months. The issue I am having now is the Temp setting on the climate control seems to get stuck and not change as it should. In manual mode, I can take the temp from 65 to 80 and it will still be blowing cold air, then the next time I get in, it is blowing extremely hot air and I can reduce the temp down as far as it will go and the air just keeps blowing hot. It's like a blend door is sticking, but it does seem to finally adjust the temp if you wait long enough or possibly cycle the ignition.
