Harman Kardon 19 speaker system
I currently own a 2021 rt with harman kardon
my buddy has a 2020 rt challenger with 19 speaker harman kardon as well i noticed a significant different in the sound from his to mine. I wanted to believe the majority of the difference is the area inside both vehicles is significantly different. I did some research my durango only has one subwoofer and the challenger comes with 2. My question is has anyone tried switch the 2 tens and put them in a durango. The amps are the same im curious if it would be a direct connect.??
Did you confirm that all the audio settings were the same between the two, such as bass, mid, treble, fader, and whether Surround was enabled or not? Was the "significant" difference just in bass output?
-Rod
-Rod
