3rd Gen Durango 2011+ models
Durango passenger window switch not working
Old Dec 17, 2022 | 01:15 PM
AliveCentaur3's Avatar
AliveCentaur3
Default Durango passenger window switch not working
Hey everyone I have a 2011 dodge durango crew awd that I'm working on and I have an issue where the passenger side window switch doesn't work at all unless I unplugged the drivers side window switch then it gets power, lights up and works.
When plugged in, the drivers side switch works perfect and will do everything. But while it is plugged in the passenger is dead.
but the second I unplug the drivers one. Now the passenger one works.
I have replaced both driver and passenger side switches and I can't seem to find the issue. Any help would be appreciated.
Old Dec 20, 2022 | 01:54 PM
SHO Rod's Avatar
SHO Rod
Have you confirmed the Window Lock button on the master (driver's) window switch panel is not activated? Does the power lock switch on the passenger door light up and function properly even with the driver's switch installed?
-Rod
Old Dec 20, 2022 | 02:03 PM
SHO Rod's Avatar
SHO Rod
Well, I took a peek at the wiring diagram which made it look like the Window Lockout switch only affects the rear windows, then looked at page 44 of the owner's manual which also confirms it only prevents the rear windows from working, so it would seem the issue is NOT as simple as the lockout switch being depressed.
The other questions still apply though regarding if the lock button lights up and if the power locks function properly from the passenger door switch even when the driver's switch is installed.
-Rod
Old Feb 3, 2023 | 02:29 PM
AliveCentaur3
Sorry never seen that I got a reply! So sorry.
still have not found the issue.
and I can confirm the lock out switch works as it should when plugged in.
