3rd Gen Durango 2011+ models
Dodge Durango 2015 V6 3.6L : performance
Old May 8, 2023 | 06:46 AM
Armelle's Avatar
Armelle
Default Dodge Durango 2015 V6 3.6L : performance
Hello
I'm New!
I have a 2015 citadel Dodge Durango V6 3.6L. I'm French and I live in France.
I have a doubt if it has an engine or gearbox problem.
when I'm on the highway at 130km/h it sometimes needs to downshift to 5 to keep the 130km/h.
it looks like the engine is shutting down.
moreover it does not go up to more than 180km/h, is there a restricted motor?
and consumption is around 15L / 100km while the manufacturer writes 12L / 100km.
do you think my vehicle has a problem?
in advance thank you for your help.
Old May 8, 2023 | 07:39 AM
dodgetruck2's Avatar
dodgetruck2
Do you have a check engine light on? Definitely sounds like an issue but something that extreme should be setting some type of fault code I would expect. Driving 130kph in 5th gear would most definitely result in poor fuel consumption as your RPM would be very high. I'm thinking 6-7000+ probably? How does the car perform from a stop, does it have alot of throttle response taking off or is it sluggish? Does it ever shift up to 8th gear?
Old May 8, 2023 | 09:38 AM
Armelle's Avatar
Armelle
thank you for your answer.
Yes, but I didn't think there was a connection. the light indicates an error code P0455 system evaporation, leak
yes, I have a lot of throttle response taking off.
and the car often shifts to 8th gear
Old May 9, 2023 | 07:24 AM
dodgetruck2
I'd ask if you checked the trans fluid but I'm not sure if you can on these or if the dealer has to do it? I even own one so I should figure that out....
