3rd Gen Durango 2011+ models
Service electronic stability control alert
Old May 3, 2026 | 09:05 PM
SHO Rod's Avatar
SHO Rod
AlfaOBD had a few recommendations on their website for dongles that are known to work well with the higher speed CAN bus and with AlfaOBD. They also offer some suggestions on bypass cables so you may want to review their website. If you're going with AlfaOBD rather than a dedicated scan tool you will want to go the route of installing a bypass cable.
-Rod
Old Yesterday | 11:12 AM
notrihulls's Avatar
notrihulls
Originally Posted by SHO Rod
If you no longer have a warranty on the Durango and you don't want to pay their diagnostic fee, or deal with the hassle of taking it in, you may now be at the point of investing in a tool to read check the diagnostic codes across all the systems. Starting in 2018 accessing several of the systems required either a bypass cable or a scan tool and $50 annual subscription to AutoAuth to unlock the Secure Gateway (SGW). I recently read that Stellantis has a different system or at least calls it something different, but I'm not sure what year that transition took place. So if you're thinking about getting a scan tool, make sure to confirm it has the ability to work with your Durango.
I was very hopefully replacing the battery would take care of the issue. I wouldn't expect it to require any amount of time to correct the issue, even if you were unable to reset the Battery Management System (BMS) after replacing the battery. But that's another feature that a higher end scan tool can accomplish for you. There may also be a particular BMS reset sequence that you can perform without a scan tool too. Actually, you may be able to access some of the diagnostic information via hidden / Engineering menus now that I think about it. That may also be worth some research. They usually involve some sequence like cycle the Start/Stop button 3 times, press and release the brake pedal 5 times within 10 seconds, then lock and unlock the doors and look at the instrument cluster display for the codes. I totally made up that sequence, but it's usually something like that to enable different features. If you find yourself needing or wanting to do these things frequently though, in my mind it's worth getting a full-feature scan tool.
-Rod
Update - I found the issue. It was the transfer case module. I watched this video on YouTube to find it -
Part No.: 68530296AA
TRANSFER CASE CONTROL
$65 with tax on Moparpartsgiant.com
Thanks for all your help folks! Saved me a ton of money at the dealersdealership.
Hopefully I won't have any more issues for a while, but I'll invest in the scanner when I do.
Old Yesterday | 01:57 PM
SHO Rod's Avatar
SHO Rod
That was a good find. Thank you for following up here with what you found the issue to be. That will likely help someone in the future.
-Rod
Old Yesterday | 11:44 PM
notrihulls's Avatar
notrihulls
I got lucky! That was why I Posted it. Hopefully it will help someone else someday. This is a great site. Keep up the great work you guys are doing!
