Ash tray LED light Ram 3rd Gen by HansonHVAC
Old Jul 26, 2007 | 08:58 PM
CarGuyOhio's Avatar
CarGuyOhio
Default Ash tray LED light Ram 3rd Gen by HansonHVAC
[/i]Mopar Part # 55361226AA
Description - Ash Tray/Cup Holder LED
Cost -$30 including tax from dealer
Install Time ->5 Minutes
[IMG]local://upfiles/15402/5FC43EE933084F0E96B2B628370FB867.jpg[/IMG]
1. Start by removing the 2 torx screws from the bottom of the panel below the steering wheel.
[IMG]local://upfiles/15402/5FEB3EE1415548149A79D291A6561CCB.jpg[/IMG]
[IMG]local://upfiles/15402/F912C6B1B40C49F09D3E2D213207598E.jpg[/IMG]
2. Next pull the on the top of the panel to remove the two clips holding it in.
3. Remove the screw behind the hook in the dash. This is a Phillips head.
[IMG]local://upfiles/15402/B0E099E75F6C4505902250B462D77BF4.jpg[/IMG]
4. Remove center bezel by pulling gently. It is help in by multiple clips.
[IMG]local://upfiles/15402/ACA22419C9D7488B84089DD609325892.jpg[/IMG]
*NOTE* You do not need to disconnect any wiring to do this install![/i]
[/i]
Here is a picture of our target destination
[IMG]local://upfiles/15402/DA7C2B49A2EF49229E1F3615A6871148.jpg[/IMG]
5. Slide Light clips into 2 holes pointed out with green arrows above.
6. Plug wiring harness from light into pre-existing wiring harness in dash
[IMG]local://upfiles/15402/F70F389E6D3945BA8C37D96609ADD255.jpg[/IMG]
*NOTE* You can plug the harness back into the hole it is clipped into by simply rotating it counter clockwise as pictured below.
[/i][/i]
[IMG]local://upfiles/15402/4A2D9830C1E245C3A16E415857419C41.jpg[/IMG]
Here is what it should look like with the lights inserted.
7. Simply put dash back together in reverse order. The LED’s come on with parking and headlights.
[IMG]local://upfiles/15402/56062801BE184C8BB1DA851A0D1AFEFE.jpg[/IMG]
Ram3rdGen
