View Poll Results: What is the diameter of your tires?
Stock (up to 33" depending on wheel)
337
75.22%
35"
95
21.21%
36"
0
0%
37"
11
2.46%
38" or greater
5
1.12%
Voters: 448. You may not vote on this poll
Tires (size and fitment)
Old Feb 23, 2010 | 01:20 AM
  #31
JoeHemi's Avatar
JoeHemi
285/70/17 mudders with deep lugs on procomp 9 inch wide alloys. Perfect fit for me.
Old Apr 4, 2010 | 08:59 PM
  #32
botrod's Avatar
botrod
looks like i have the same question as many do. I have an 08 big horn with the stock 20" rims. I'm adding a 2" levelling kit. The tires are cupped terrible and I need to replace them. My local tire shop hasn't been much help and the prices they quoted are pretty steep. What sizes can I fit? Looks some are saying 33/12.5 and 35/12/5 or 13.5 all fit. I'm in PA and they can't stick out they won't pass inspection.
Give me some help on this please. I'll even take some recommendations on tires. I've looked at the Cooper ST and the MT ATZ. I want something with good road manners but fairly aggressive.
Old Apr 5, 2010 | 09:33 AM
  #33
Solid_Crimson28's Avatar
Solid_Crimson28
i have 295/60/r20 on stock 20 inch rims. the rub at full turn. but they stick out a bit. although i had to get 1/4 inch wheel spacers to make them fit. cuz they were to wide to begin with, they were touching the control arm. they are nitto terra grapplers. look aggressive and very good on my truck. if you look at the specs on the nitto website they are 34.5/12.36 tires. a little bigger than normal 295/60s.... but since you live in PA they do stick out a bit maybe an inch or inch and a half. but if you get a tire with specs close to that you may need the 1/4 inch wheel spacers. Good luck
Old Apr 7, 2010 | 12:13 PM
  #34
botrod's Avatar
botrod
I think I'm going to try 275/65/20. They are 1.1" taller and .5" wider from what I can tell. That should keep me PA legal but give me a little extra height.
Old Apr 7, 2010 | 10:37 PM
  #35
islander26's Avatar
islander26
Default Need help asap
HI RAM LOVERS I HAVE A HUGE PROBLEM I HAVE A 2004 DODGE RAM HEMI 2WD AND I JUST BOUGHT A 7" CST LIFT I WANNA KNOW WHAT WHEEL SIZE WOULD FIT ON MY DODGE...ITS BETWEEN NITTO'S,TOYO'S, BF GOODRICH, AND MICKEY THOMPSONS....CAN YOU PLEASE LET ME KNOW WHAT WOULD FIT ON MY DODGE RAM THANK YOU VERY MUCH
Old Apr 23, 2010 | 02:02 PM
  #36
haulinhemi06's Avatar
haulinhemi06
305/55r20. fit good. a little small. slight rubbing. metal grinder took care of that. going with 275/65r20 next. no rubbing, 34" tall and still get full wheel articulation.
Old Apr 23, 2010 | 04:55 PM
  #37
98cherryram's Avatar
98cherryram
35X12.5 toyo mt's. Best tire Ive ever owned.
Old May 23, 2010 | 01:55 AM
  #38
bound2bmine's Avatar
bound2bmine
I have 275/60r20 on the stock rims can I go with a slightly wider tire. I have no lift at all. I just would like to go a little wider.
Old Aug 3, 2010 | 12:19 AM
  #39
SnowFox's Avatar
SnowFox
this is the 05 i had with 6" fabtech lift and 35x12.50r20s
i miss it....
Old Oct 9, 2010 | 10:23 PM
  #40
$Piker's Avatar
$Piker
2007 Hemi Ram 2500. 100% Stock with 295/70r17 nitto terra grapplers. No rubbing issues at all.
