DIY Ball Joint Replacement
Old May 20, 2010 | 03:50 AM
  #51
Lifted Dodge's Avatar
Lifted Dodge
Default Same for 2001 Ram 1/2 ton?
Is all this pretty much the same for my '01 half Ram? My lowers seem very secure L/H and R/H. Uppers are shot indeed...
Old May 20, 2010 | 08:41 AM
  #52
steve05ram360's Avatar
steve05ram360
IIRC the rotors are also floaters so yeah it should pretty much apply to the 1/2 ton. I had been suggested in this thread http://www.cumminsforum.com/forum/3r...ml#post2293965 that I used the press wrong and that may be why it bent.
Go about 1/2 way down and you'll see the changed pic of an alternate method...
Old Jul 6, 2010 | 10:10 PM
  #53
jkoz79's Avatar
jkoz79
Default Saved my life
This article saved my life yesterday, it only took me 6 hours to do the U-Joints, without it may have been 10. Even though you posted it as Ball-joints, lots of info here to help with other projects. Thank you
Old Jul 6, 2010 | 11:14 PM
  #54
steve05ram360
no problem, glad it is helping!
welcome to DF...
Old Jul 8, 2010 | 08:27 AM
  #55
synner's Avatar
synner
I've done all the ball joints and u joints in the front of my 05 2500 for the second time in a year this past week and this forum/posting is a huge help. Now if only we had all metric or all imperial fittings on the front end this repair would be a breeze.
Old Jul 8, 2010 | 10:08 AM
  #56
steve05ram360
ouch, 2nd time in a year... look at the dynatrac ball joints for a better solution or XRF's are supposed to be good.
I have the Carli uppers & may be doing the Carli lowers soon as the moogs that are in there now are not cutting it. having it checked for play tomorrow.
Old Jul 9, 2010 | 11:02 AM
  #57
fiddlerkelly's Avatar
fiddlerkelly
Synner , what brand ball joints did you put in your truck that only lasted a short while. I know it is only a matter of time and I will have to do mine and I don't want to be replacing them within a year after doing them.
Old Jul 9, 2010 | 01:41 PM
  #58
sprntpshr's Avatar
sprntpshr
Good article and pictures. I have the u-joint and ball joints on the RS of my 03 3500 QC to do. LS was done a few years back by shop, they gooned the hub, knuckle and broke all 4 bolts in the process, $1100 bill. Not this time.
We have done a couple of Ram 1500's and other than a few less bolts, its about the same deal. I found if I didn't have the press lined up straight with the ball joint then it was very difficult to press them in and out. Parts Source here has a press to borrow for free, and that is a good deal.
sprntpshr
Old Jul 9, 2010 | 01:44 PM
  #59
sprntpshr's Avatar
sprntpshr
Never been able to figure out why bolts and fittings are all mixed; Imperial and Metric. Just a PIA as far as I can see.
sprntpshr
Old Jul 9, 2010 | 03:28 PM
  #60
synner's Avatar
synner
Tried another set of OEM Dodge ball joints as I had heard mixed reviews on the Moogs. Have to remember this is a plow truck and I work the pants off of this thing.
This time I put Moog units in so we'll see what happens. If my pockets were deeper I would have had Carli but not this time. Maybe next round which is probably going to be next spring, haha.
I've heard of shops doing the hub/bearing everytime they do the ball joints or front u joints as they can't get the hub apart? Seems like an expensive way to change a ball or u joint.
