View Poll Results: What brand wheels are on your truck?
Mopar (stock)
167
61.17%
XD Series
21
7.69%
Weld Racing
0
0%
Cragar
7
2.56%
Diamo
2
0.73%
Mickey Thompson/Dick Cepek
11
4.03%
KMC
1
0.37%
Pro Comp
8
2.93%
Moto Metal
15
5.49%
American Racing
9
3.30%
Eagle Alloys
7
2.56%
OTHER (please specify in a post)
25
9.16%
Voters: 273. You may not vote on this poll
Wheels
Old Feb 8, 2009 | 05:23 PM
HammerZ71's Avatar
HammerZ71
Default Wheels
A quick poll of what wheels people are using, then some basic wheel terminology and general information.
Bolt pattern or lug pattern or bolt circle is determined by the number of bolt holes and the bolt circle diameter. The bolt pattern on a 3rd Gen 1500 non MegaCab is 5 on 5.5 and the bolt pattern on all MegaCabs and 2500 series trucks is 8 on 6.5.
Hub Diameter or center bore is the hole at the center of the wheel.
Rear spacing or back spacing is the distance from the backside of the wheel mounting pad to the outside of the rim flange.
Offset: The distance from the centerline of the wheel to the mounting surface of the wheel.
Negative offset: When the back of the bolt pad is closer to the inside of the wheel; when mounting surface is inboard of the rim centerline.
Positive offset: When the back of the bolt pad is closer to the street side of the wheel; when the mounting surface is outboard of the rim centerline.
Old Feb 8, 2009 | 06:41 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I voted for the stock option since that is what I am running. But mine are the aluminum 20's off of an 07 Ram that I coated black back in October. Best $250 I ever spent.
Old Feb 8, 2009 | 08:53 PM
matty_p's Avatar
matty_p
Running stock aluminum 17's. Want to get them painted, but waiting till the rest is done.
Old Feb 8, 2009 | 11:22 PM
raminator08's Avatar
raminator08
22's!
Old Feb 9, 2009 | 02:39 AM
hemiyellow's Avatar
hemiyellow
DC Insider
well i had SRT10 22" but now i'm stuck with some eagle 17" lol...man aint that a bi*ch
Old Feb 9, 2009 | 01:47 PM
Bigbody's Avatar
Bigbody
I found a replica wheel for the str, they look just like the 22" but they are 20" and i kept the stock rubber for now
Old Feb 10, 2009 | 10:58 PM
hemiprince's Avatar
hemiprince
I have 2003 20" wheels, I was wondering if anyone knows what the backspacing measurements are? I am trying to go with a lift and one of the lifts I am looking at said for it to work I would have to have a minimum of 4.5" what does that mean?
Old Feb 16, 2009 | 01:22 PM
Redone4x4's Avatar
Redone4x4
Eagle 17's on mine...17x10, not sure on backspacing though. i really like em.
Old Feb 16, 2009 | 06:52 PM
MOPAR78's Avatar
MOPAR78
Not to sure of the brand, I forget but they are SRT 22'' Rep.'s
Old Feb 18, 2009 | 04:53 AM
Army_HEMI2WD's Avatar
Army_HEMI2WD
this is how you measure your backspacing guys:
How to Measure Wheel BackSpace
Items required to measure wheel backspace: Tape measure Straight edge Wheel w/o tire (preferred)
The easiest way to measure backspace is to lay the wheel face down onto the ground so the backside of the wheel is facing up. Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub mounting pad of the wheel. This measurement is backspace. The above photo shows three wheels with 2",3", & 4" backspace.
