Seat Cleaning 06-08 Ram by The Peddler
06 seat cleaning!
When you are trying to clean a stain out of your seats, you have to clean the whole seat. You can use any cleaner you want or just use water.
1. If you are using a cleaner, spray the whole seat down. Use a cloth to soak up as much of the cleaner as you can. Make sure to spend alittle more time on the stains you might have. If you are just going to use water, make sure the water is as hot as you can get it. Damp a cloth with the water and start washing your seat down, remembering to keep you cloth damp.
2. After you get your seats clean, you can dry them a numberof ways. Somepeopleuse a hair dryer or a steam cleaner, but the best way that I have found, is to leave your windows down, and open your doors so that the wind does your drying for you. This takes about a half of a day or so, but if you got the time this is the best way to dry them.
3. After you get your seats clean and dry, you need to put some protector on them so you don't have to clean them all the time. Get you someScotchgard, this stuff is great, to put on your seats. You need to put 3 or 4 coats on, make sure you let it dry from one coat to the next. Make sure your coats are light and even.
If you do this, your seats will be clean, and look great. Any thing you might spill or get on your seats will wipe right up.
Ram3rdGen
Ram3rdGen
