DIY Brake Controller & Trailer Wire Install
Old Aug 30, 2007 | 08:23 AM
rtmorrisjr's Avatar
rtmorrisjr
Default DIY Brake Controller & Trailer Wire Install
I found this information on www.etrailer.comI have used this site before and want to say that they have great prices and vey quick shipping. They had a nice write up on how to wire our trucks for trailers/trailer brakes. From having a factory installed (and just needing the brake controller) to starting from scratch.
Factory Installed 7-Way
[/align][/align]
If you drive a newer Dodge Ram Truck (~1995 - Present) and your vehicle already has the factory installed 7-Way trailer connector then only a couple parts are required.
Parts Needed:
[ol][*]The Brake Controller[*]The Universal, Tekonsha, or Valley Brake Control Adapter
[ul][*]Sometimes this will be provided by dealer.[/ul][/ol]
Step 1:
Start by plugging in the brake control adapter into the OEM harness located under the steering wheel, just to the right of the emergency brake pedal. Then find a place to mount the brake controller. It should be in a position that is easily accessible. Cut the wires to the proper length and then connect. Installation is now complete. Note: Fuses may need to be installed under the hood.
First connect the Brake Control Adapter to the Brake Controller. The factory adapter uses different colors, but the wires are labeled. The wires match up: red to red, black to black, white to white, blue to blue. Then plug the adapter, which is now connected to the brake controller, into the plug under the dash. Then mount the brake controller to a place on the dash. Make sure that it is easily accessible.
OEM Plug is usually blue.[/align]
Brake Controller where it is easily accessible.[/align]
[/align][/align][/align]
[/align][/align][/align]Factory Installed 4-Pole
[/align][/align]
If you drive a newer Dodge Ram Truck (~1995 - Present) and your vehicle already has the factory installed 4-Way flat trailer connector then only a few extra parts are needed. Although not all late model trucks with a 4-pole has the brake controller plug. Make sure to double check if you have a 2005-2007 model truck to see if the truck as the correct port.
Parts Needed:
[ul][*]Sometimes this will be provided by dealer.[/ul][*]7-Way or 6-Way 4-Pole Adapter[*]Wire - number of feet depends on truck bed size and hot lead [/ol]
Step 1:
Start by plugging in the brake control adapter into the OEM harness located under the steering wheel, just to the right of the emergency brake pedal. Then find a place to mount the brake controller. It should be in a position that is easily accessible (See Above). Connect the wires. If the port is not available, see the start from scratch.
Step 2:
Usually located under the driver's side of the vehicle, right behind the front wheel well is a wire connector. As you can see in the picture there are more wires on the hood side (right side) of the connector than the hitch side. Using a circuit tester you can locate the wire that supplies power to the trailer brakes. Usually it is the blue one. Using a scotch lock, run a wire lead from the blue wire to the back of the vehicle. Enough wire will be needed to make it from the front wheel well to the end of the truck bed. The wire lead will connect to the blue wire on the 7-Way or 6-Way trailer adapter. After mounting the new trailer adapter and plugging it into the original 4-pole connector, installation is complete.
Note: If a hot lead is needed, it would need to be connected to the battery via a circuit breaker. That wire would then connect to the black wire on the trailer connector adapter.
Starting From Scratch
[/align][/align]
Parts Needed:
[ol][*]The Brake Controller[*]The Brake Control 7-Way or 6-Way Installation Kit or one of Draw-Tite's Installation Kits (5505 or 5506)[*]4-Pole Trailer Connector for the Vehicle
[ul][*]If needed, use the Hitch Finder to see the quick, easy, no-cutting wiring adapter that is recommended for your vehicle.[/ul][/ol]
Step 1 - In the Back:
Start in the rear of the vehicle by first installing the 4-Pole trailer connector. Next, find a good place to mount the 7-way or 6-way trailer connector and then connect it to the newly installed 4-Pole. Ground the 7-Way or 6-way connector and run the extra-long wire lead up to the front of the vehicle. A good place to run the wire is between the truck bed and its cross members.
[/align]
Step 2 - Under the Hood:
After slicing open the sleeve that holds the two wires, run the blue wire through a hole in the firewall. This will connect to the brake controller and carries the signal that activates the trailer brakes. The other wire will be for a "hot" lead (if needed) and will run to the battery through a circuit breaker.
Finding a hole in the firewall can sometimes be a little difficult. Before drilling a hole, always look for wires already running through the wall. On this Dodge, a hole was found just to the right of the emergency brake pedal (see picture close to bottom of page). It is often easier to run the wires through the hole by removing the grommet and put a slice into the grommet. Then insert the wires into the grommet and reinstall.
[/align]
Find a safe place to mount the circuit breakers. The hot lead attaches to the 40 amp circuit breaker given in the kit. The 20 amp circuit breaker is for the brake controller power supply
Note: Some brake controller models require a 30 amp circuit breaker which is not included in the installation kit. Also a smaller circuit breaker or an in-line fuse can be used on the hot lead.
[/align]
Run two wires to the battery on from each breaker. Each post on the circuit breaker is labeled. Be sure to connect the battery to the post labeled "BATT" on the breaker.
[/align]
After connecting the wires to the positive post on the battery, the ground wire will need to be run to the negative post. Start at the battery and route the wire back through the firewall. It will be connected to the ground wire on the brake controller (white wire).
[/align]
Now that all the leads are run into the cab, the red wire on the brake controller needs to be connected to the brake pedal.
To do this, follow the wires connected to the switch at the top of the brake pedal. Using a circuit tester, find the wire that carries the signal once the brake pedal is engaged. Usually it is the white wire with a tan stripe. Scotch lock the brake controller's red wire to this one.
[/align]
Before connecting the rest of the wires to the brake controller, be sure to remember to slide the wires through the grommet in the firewall. Connect the ground wire to the brake controller last.
[/align]
After mounting the controller where it is easily accessible, installation is complete.
[/align][/align][/align][/align]
