Leveling a '07 Dodge Ram 1500 2wd
Old Aug 12, 2009 | 12:22 AM
Freakinkeith806's Avatar
Freakinkeith806
2 inch level here:
Old Aug 12, 2009 | 07:07 AM
explorer9950's Avatar
explorer9950
http://www.autotrucktoys.com/ram/Day...8453C4675.aspx
There is the 2.5" spacer for 2wd...I have this one on my truck and the look it gave it is perfect...I have an 07 also...
Old Apr 1, 2011 | 09:44 PM
Eklipz93's Avatar
Eklipz93
CoreyStone11, actually there is a 2.5 LEVELING kit for 07 2wd DODGE RAM. I live in Sacramento California there is a place here called AUBURN LIFTS, let me know if u need more info (FYI) i drive a 07 single cab with a 2.5 leveling kit on the front using stock shocks with 33" nitto trails and it looks and rides great pics soon....
Old Apr 1, 2011 | 11:03 PM
Matt99's Avatar
Matt99
A true 2.5 on a 06-08 2wd will not ride great.
Old Apr 2, 2011 | 05:43 PM
Eklipz93's Avatar
Eklipz93
Matt99 i dont have any problems. Maybe something went wrong with your lift, it also depends on what brand.
Old Apr 2, 2011 | 06:00 PM
Matt99's Avatar
Matt99
No it doesn't depend on brand. A true 2.5" lift (which would be a 3" spacer) on the 06-08 setup causes UCA and spring bucket contact. Period. The stamped steel Upper Control Arm hangs too low and hits the top of the spring bucket with downward travel. With a 2" lift (2.5" overall spacer) will still cause this but not as pronounced. Also, the stock shock technically is overextended past 2".
That's all with an extended spring or spring spacer. If you have a 3" or 4" spindle that all doesn't apply. Eklipz, what kind of 2.5" level do you have? Not brand, I mean mechanically. What does your truck's front fender measure at?
Old Apr 17, 2011 | 08:36 PM
Plainbroke's Avatar
Plainbroke
Good information Matt99, I will stick with the 1.5" daystars.
Old Apr 17, 2011 | 09:19 PM
Matt99's Avatar
Matt99
no you are okay with even 2.5" if you are driving the truck in your sig. the 02-05 trucks have a skinnier control arm. I have heard of people even fitting 3" spacers on your models
Old Apr 18, 2011 | 12:21 AM
Razorhawg's Avatar
Razorhawg
cheaper ways of doing it but im going with the readylift 2.25"
http://www.readylift.com/c-231-dodge...-only-225.aspx
Old Apr 18, 2011 | 10:28 AM
Matt99's Avatar
Matt99
Razor, make sure to measure what you really get
