4x4 help and advice
Old Jul 27, 2010 | 10:56 AM
ChelseaFC's Avatar
ChelseaFC
Default 4x4 help and advice
Just got a oversand beach pass. I have an 07' Thunder road package. (aka big horn)
20x9 tires quad cab 4.7V8
My elec 4x4 switch says 4hi-lock and 4 lo. Whats the difference. Can anyone give me the low-down on my transmission?
what should I use? Are these trucks good in sand? should I deflate tires?
Old Jul 27, 2010 | 10:58 AM
osp1560's Avatar
osp1560
Four low is for off roading during slow situations when you need more power and less speed.
Old Jul 27, 2010 | 11:56 AM
Marx's Avatar
Marx
4hi up to 88km/h
4low up to 25km/h
give or take
if you read the manual it explains eveything
Old Jul 27, 2010 | 12:55 PM
HammerZ71's Avatar
HammerZ71
Better air down for the beach, the softer the sand, the more you need to air down...
Old Jul 27, 2010 | 09:44 PM
sbsga's Avatar
sbsga
its a good idea to find some soft ground(dirt road or some grass will do fine) about once a month or two and throw it in 4hi to keep things in good operating condition for when you need it. not a long way, just a 100 feet or so. Also try to avoid turning the wheel all the way over when 4wd is engaged, that will help keep the stress as low as possible on the axles. and like marx said the manual has a pretty good instruction on how to use it.
Old Jul 29, 2010 | 01:18 PM
RubberFrog's Avatar
RubberFrog
4 lo, 25 psi in the tires
You'll be fine.
