Do people get mad at you for having HID's?
Old Aug 10, 2010 | 12:43 AM
Matt99's Avatar
Matt99
rant any, Rocket?
lol yea I try and get as close as I can at redlights and traffic so that my lights are pointed at their bumpers instead of glaring and angling into the side mirrors. Seems to work alright.
Old Aug 10, 2010 | 08:42 AM
PhotogTom's Avatar
PhotogTom
Originally Posted by ram man17
I only get flashed when I drive with my fogs on...With the fogs on I am guarenteed to get flash about 10 times in a night.
Foglights shouldn't be pointed upward at all. They're really pretty bright if they're pointed straight at your eyes. If you've leveled or lifted your truck, yours are probably pointing upward a bit, causing them to shine directly into other drivers' faces.
From the link in my earlier post, they state that at 25 feet distance from the wall that you are using to aim your lights, the top of the light beam from the fogs should be 1.5 inches below the height of the center of the fog light from the ground (if the height of your fogs is 18 inches from the ground or less). If your fog lights are between 18 and 28 inches from the ground, the top of the beam of light should be 3 inches below the the amount of height from the center of the fog light to the ground.
Old Aug 10, 2010 | 10:53 AM
pjordan4477's Avatar
pjordan4477
Sounds like others got the info.
I've been flashed with new cars on lo-beams...I just flash back to let the idiots know they are WRONG!!!
Old Aug 10, 2010 | 03:47 PM
ram man17's Avatar
ram man17
I did level my truck so I will go out tonight and try to fix them...and im with you jordan. If i get flashed with the fogs on I turn them off but if someone flashes me with jus my low beams then they get flashed right back......or the train horns
Old Aug 11, 2010 | 02:23 PM
rocket23's Avatar
rocket23
personally i firmly believe that some people hate the fact that your running fog lights period. and will flash you just because their on. Friggin panty waste's!
Old Aug 11, 2010 | 03:04 PM
gn300's Avatar
gn300
It doesn't sound right to "flash at fogs", as they are designed to light up a short distance in front and to the side of the car.
If they are propery aimed up/down AND left /right then there should be no issue....
Old Aug 11, 2010 | 08:35 PM
AWE Daniel's Avatar
AWE Daniel
Aren't fog lights designed to bounce light off the ground up into the fog? They shouldnt be in anyones face
Old Aug 12, 2010 | 07:05 PM
rocket23's Avatar
rocket23
I've drivin. with fogs on in a mitshubishi lancer. Low too the ground and the fogs were factory, I had a-holes flash me routinely. just because they were on. mind you I live in Ct. These people are in a hurry to go nowhere, can't seee shlt without high beams on, and complain that there is way to much traffic, while they do 55 in the left lane. Of course they flash my fog lights. lol
Old Aug 12, 2010 | 07:15 PM
AWE Daniel's Avatar
AWE Daniel
I have yellow bulbs in my fogs and during the day I turn on the parking lights with the fogs, kinda my version of DRLs, and at night they are on too, people dont like it, then F*** em its perfectly legal
Old Aug 12, 2010 | 07:36 PM
glass3222's Avatar
glass3222
I do not have HIDs, but I recently went on a road trip from PA to FL and I was blinded by many people with HIDs. I really do not like HIDs after that trip. If people are flashing you and flippin you the bird because of them, you need to get them adjusted correctly or take them out, IMO.
