my CAT is going
Catalytic Converter is going bad so I called the dealer and they want 1000 dollars so am going after market can somebody give some advice I found this on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
The Maggy hi-flow cat works well, but be aware that this cat may cause a CEL which would cause a fail in most inspection states. Most often if you get a CEL, the non-fouler trick (search - its all over this section and in the FAQ) will clear the CEL and allow you to pass inspection...
