eraser wheel
Old Sep 27, 2010 | 01:16 AM
Atwiss's Avatar
Atwiss
Default eraser wheel
i was wondering if the eraser wheel will remove the stripe on the back of my truck it is painted on because i did a little test run behind the tire in a un noticable spot and sprayed some decal remover/paint stripper and it smeared off but i think its taking the clear coat of, but i was wondering if it will remove the paint since its above the clear coat thanks
Old Sep 27, 2010 | 08:06 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yes an eraser wheel will do just what you are looking for. It should take it off fairly easy but do not set there and run the wheel in one place for long. Hit and go. Then come back with a good wax.
