bore 5.7
Old Oct 10, 2010 | 07:00 PM
blackbetty696's Avatar
blackbetty696
Default bore 5.7
i went through the past threads and couldn't find anything useful i was wanting to know what is the max i can bore my 5.7 also wanted to announce the new toy i was going to get for full pic its the second to last one down http://www.xvmotorsports.com/product...x.cfm?nPID=275 its the manifold and nitrous kit
Old Oct 10, 2010 | 08:01 PM
RedTruck-VA's Avatar
RedTruck-VA
The manifold looks to me as a horsepower maker. Lets us know what you think of it when you get it installed.
Old Oct 11, 2010 | 01:44 AM
FrostKing's Avatar
FrostKing
You will not be able to use the elbow from XV unless you have an LX front cover or you ditch your A/C and use a 3" spacer:
http://dl.dropbox.com/u/156775/IMG_1522.jpg
Old Oct 11, 2010 | 05:21 AM
RedTruck-VA
I read that with a 1" spacer the elbow can be rotated 90 degrees over the passenger valve cover. I don't have personal experience in doing this. But believe this was for trucks only.
Old Oct 11, 2010 | 06:41 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The best place to ask about how big of a bore you can get is a local machine shop being they have the books. Normally, 0.060" of an inch is traditional but thats also on older engines where they had thicker sleeves to bore out that big.
Call Art at Hensons Motorsports or Stu an Inertia Motorsports and they can better answer how much you can actually bore. Make sure whatever shop does the boring for you that they use a deck plate to keep the sleeves straight while boring.
Old Oct 11, 2010 | 12:38 PM
FrostKing's Avatar
FrostKing
The problem with this is the throttle body will be resting on the ign coils and back near the a/c accumulator. Probably not a problem with n/a but this sucks for forced induction.
Old Oct 11, 2010 | 03:46 PM
dirtydog's Avatar
dirtydog
Moderate User
Going for the biggest bore won't necesarily give you the best bang for your buck. I would reccomend doing a stroker kit if your looking for some serious HP upgrades.
Also, You may want to be careful on maxing out your bore if you plan to run a blower or Nitrous. You want a little more wall thickness when going that route.
if you plan to run nitrous because of cost, i would reconsider. N20 is very expensive to do properly and there's constant cost involved, where as N/A is a one shot deal.
Old Oct 11, 2010 | 05:04 PM
oefootball_70's Avatar
oefootball_70
You can bore the 6.1 hemi to a 7.4.
I know you can bore the 5.7 to a 6.7 after that, I don't know.
Old Oct 11, 2010 | 05:05 PM
oefootball_70
http://www.shophemi.com/p-1166-57l-h...ce-engine.aspx
