will these rub?
Old Nov 17, 2010 | 09:30 PM
HemiRam1566's Avatar
HemiRam1566
Default will these rub?
im getting 285/70/17's next week (33 x 11.50) and i have heard you can fit 33's on a stock ram but right now i have 265 70 17's and the tires looks pretty close to the spindle, will my 285's rub?
Old Nov 17, 2010 | 09:33 PM
HemiRam1566
and its a 07 4x4
Old Nov 17, 2010 | 10:22 PM
dirtydog's Avatar
dirtydog
Moderate User
They will be very close, but guys have put that size on without rubbing.
I have 275's in a 33" tire and JUST measured my clearanc last week. I have 5/8". 285's ren't even 1/2" wider than 275's which would mean the tire distributes that evenly to the inside and outside of the rim. Therefore, you will see at most 1/4" closer to your spindle/upper balljoint. Still leaves 3/8" of clearance!
sorry for getting all technical on a simple YES answer. Just wanted to reassure you. ;-)
Old Nov 18, 2010 | 11:38 AM
bigmac18's Avatar
bigmac18
A friend of mine just put a set of them on a 2007 2wd, so they should fit without a problem
Old Nov 18, 2010 | 08:40 PM
HemiRam1566
great thanks for the info guys... i can slide my hand in-between the tire and the spindle so it should be good! cant wait to get some real rubber on her!
Old Nov 18, 2010 | 11:46 PM
kx250frider617's Avatar
kx250frider617
I have 305/70/17 on mine but I have torsions up front.
