Drivers door lock switch.....
Old Dec 14, 2010 | 05:16 PM
bigdaddyII's Avatar
bigdaddyII
Default Drivers door lock switch.....
Since I bought the truck I have not been able to lock/unlock the power door locks with the drivers switch. The passenger side works fine. I always thought it was the drivers switch assembly and when it bothered me enough I would replace it. Recently I started having trouble with my passenger side window switch. It would lower the window but would take quite a bit of playing with the switch to get it to go back up. When this would happen with the drivers switch the passenger switch would not work either. I let it get to the point that in the past week I wondered on several occasions whether or not I was going to get the window back up, so I went to the Dodge parts dept and bought a new assembly. $128 later all of my windows work from each respective switch as well as the drivers switch. The power locks did not however. I dont hear any motors running, any trying, nothing. This disappoints me as its a pain in the *** to keep leaning over to unlock the doors when someone wants to get in (picking someone up, waiting in car for someone) as the doors automatically lock upon starting vehicle.
I have checked fuses, opened the door and checked wires in the loom going from the door to the cab. No dice on any of it. The truck does have an Aviatla alarm installed, that was installed when I bought it. I downloaded and printed an installation manual for the alarm and traced all the wiring and it is all correct. Any ideas? Im at a loss and wanting to get this taken care of.
Truck is a 2002 1500 qc.
Old Dec 23, 2010 | 05:16 PM
bigdaddyII's Avatar
bigdaddyII
UPDATE!
I uninstalled the Avital alarm. Geez what a nightmare of tracing spaghetti noodles. Anyhow, all wires are intact and eveeeerrrrrrryyyyyyyy one was traced. Still same scenario, all locks work with passenger side lock switch, drivers side is still dead. At the very least, is it possible to keep all locks from unlocking when door is opened after turning truck off? Thanks.
Old Dec 26, 2010 | 10:05 PM
mike_r's Avatar
mike_r
I know when mine theres a sequence of step that you can do that disables automatic unlocking of doors when the driver side is opened. The easiest thing you can do is just open the door before you turn the tuck off and that shouldn't unlock everything else. Try checking in the user manual to see what those steps are.
