275/65R20 Will they fit?
Old Dec 21, 2010 | 08:01 PM
will17's Avatar
will17
Default 275/65R20 Will they fit?
I have a 2005 1500 with 275/60R20. I want to get a larger tire to look more aggressive but do not want to lift or make any suspension change. Will this larger size fit without rubbing? Will it change my speedometer by a lot? Thanks for your help.
Old Dec 21, 2010 | 08:13 PM
jake7's Avatar
jake7
yes they will fit.
Old Dec 21, 2010 | 10:24 PM
cjs4444's Avatar
cjs4444
use this for the speedo difference.
http://www.miata.net/garage/tirecalc.html
Old Dec 21, 2010 | 11:07 PM
Marx's Avatar
Marx
ya you will be fine with that
Old Dec 22, 2010 | 06:43 PM
HemiLonestar's Avatar
HemiLonestar
305/50R20's fit, so you'll be fine.
Old Dec 22, 2010 | 06:47 PM
glass3222's Avatar
glass3222
305/50R20s are only 32" tall
275/65R20s are 34.1" tall so there is a good bit of height difference.
You still should not have a problem, if you do crank the torsion bars up a little and they will fit great and you will be closer to level.
Old Dec 22, 2010 | 10:33 PM
MeAndMyHemi's Avatar
MeAndMyHemi
Do you have any trouble with rubbing when you turn?
Old Dec 23, 2010 | 05:26 PM
04_ramslt's Avatar
04_ramslt
I had no clearance/rubbing issues with 275/65/20 on my 04 2wd so you should be fine
