fog lights in an st bumper?
Just curious if anyone here has done it before, or if there is a how-to kicking around for it.
Basically, my truck has the black and chrome bumper without foglights. Obviously, I have the holes where they are supposed to be, but they are filled with a plastic piece with 3 vertical "lines". Anyone know if i can just order stock fogs and mount them? or what else I'd need to do? any help would be awesome. |
You can take that vent out and put fogs in the place. Then sell the vents if you want to. A factory setup sold on ebay would be best but make sure the truck is pre-wired for fogs. Also, sometimes the trucks PCM/FCM isnt programmed for fogs so that means a trip to the dealer and a plug-in with the Starscan which means $$$
I could add my own wiring and hook them up to a separate in-cab switch if i wanted though no? regardless of factory wiring or not?
yes they sell a kit for both ways on e-bay. I installed my own wiring so that I can run them even with the high beams on. this is who I got my kit from and it was great. http://cgi.ebay.com/ebaymotors/Dodge...ht_1612wt_1165
if its already prewired then you save yourself a step and a few dollars since you only need fogs and switch.
Originally Posted by bartvandenberg
(Post 2384853)
