DIY for Differential oil change
Old Feb 13, 2011 | 03:55 PM
sinus19's Avatar
sinus19
Default DIY for Differential oil change
Sup guys!
So i decided that im going to change the oil on both of my Diffs (4x4) I will take off the covers and take a look as well as take pictures for you guys to see. But i need to know how to put the oil back inn??? sorry for the newb question but it is my first time doing this, So i would much appreciate if you guys could give a DIY describ. And what oil should i use? (140K miles) Thanks!
Old Feb 13, 2011 | 07:13 PM
cg1022's Avatar
cg1022
In the middle of both you diff covers there is a rubber plug that has DANA written on it pop it off and fill until it leaks out, than push the plug back in. If the plug is dry rotted I advise you go get a new one because it WILL leak.
Old Feb 14, 2011 | 01:18 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Maybe this will help
https://dodgeforum.com/forum/3rd-gen...-tutorial.html
Old Feb 14, 2011 | 10:43 PM
davb673's Avatar
davb673
I have one that includes installing a Powertrax Lockrite at the same time, if you are interested... I'd post it but I am not able to as I am 0.4k within my attachment limit. The file is 800K.
[edit] PM me and I'll email it to you...
