lower control arm strut bolt
Old Feb 21, 2011 | 07:09 AM
ramMan9967's Avatar
ramMan9967
Default lower control arm strut bolt
I've read that some of you had to change the lower control arm strut mounting bolt. I have to as well I think but im not sure.. is the bolt stepped down in the middle or is it supposed to be straight like any other bolt. .just trying to find out if the bolt is warn down or if its suppose to look the way it does
Old Feb 21, 2011 | 08:27 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can post a picture of your bolt and we can tell you if it is normal or not. But overall you should be able to look at it and see if it is worn or abnormal.
Old Feb 21, 2011 | 09:05 AM
ramMan9967's Avatar
ramMan9967
Im guessing its warn..it took alot to get it out
Old Feb 21, 2011 | 10:25 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
That could just mean it wasnt aligned right making it more difficult to get out.
