leveling kit pics
I opted for the 2in leveling kit with the pro comp shocks all the way around from fatbobs garage.
i needed to do the upper, lower ball joints and the outer tie rod ends, so i figured i would do a leveling kit while i was in there.
the lower ball joints on this truck were a PITA. we needed the torch to get them out. i don't think we could have done it with out the oxy acetylene.
also go to advanced auto and get the 23 piece ball joint press kit. the 5 or 6 piece kit just is not going to have the sleeves you need in it.
the kit was supposed to be two inches, but as you can see here, its a bit more in reality.
now i have serviceable upper, lower ball joints and tie rod ends, i dont know why dodge did not do these from the factory.
Before
After
Before
After
