CAI Question Update(done!)
Old Feb 27, 2011 | 11:51 PM
Matt99's Avatar
Matt99
ok i will when i get my truck back.
to see your heat sat, drive for awhile and then pull over and see if your pipe is hotter than the air temp. if so, its holding onto heat
Old Feb 28, 2011 | 05:48 AM
ricer's Avatar
ricer
Ok think I am just gonna switch it out tonight. Like weedahoe said live and learn.
Old Feb 28, 2011 | 07:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
For telling the heat saturation and absorption on the metal versus plastic (composite, ABS, PVC, ECT) you would need a tuner to read the temps on the IAT sensor and the sensor would have to be far enough at the end of the intake to see the difference.
Old Feb 28, 2011 | 07:41 AM
olyelr's Avatar
olyelr
Maybe I am overlooking something in the pics, but isn't that just new pipe to the original filter box? What good would that do?
Old Feb 28, 2011 | 03:14 PM
tedberchtold's Avatar
tedberchtold
i was sorta wondering the same thing.
Old Feb 28, 2011 | 05:18 PM
BadHab1t's Avatar
BadHab1t
it eliminates the hemi hat, which is super resrictive on air flow, this is like getting a airraid mit tube...
Old Feb 28, 2011 | 08:54 PM
ricer's Avatar
ricer
Yea it's basically the same thing as the airaid mentioned before. No, it's not a $350.00 CAI but that is also why I nicknamed it the "poormans CAI". I have noticed a considerable difference in the throttle response and seems to have a little bit more power climbing hills,doesn't seem to work as hard.
Old Mar 1, 2011 | 07:00 AM
olyelr's Avatar
olyelr
Gotcha. So, basically its just some pipe (3"?) and elbows and couplings? Hell, even I could handle something like that
Old Mar 1, 2011 | 07:17 AM
BadHab1t's Avatar
BadHab1t
it makes a big difference, no one realizes how restrictive the "hat" is, my intake is by no means no big name or high priced, i opted for a mopar knock off, and i love it, it was like $75 shipped...made well havent had any problems with it, yet it is aluminum, i have not noticed any heat saturation with it, and ive pulled readings from my s/c...
Old Mar 1, 2011 | 08:11 PM
ricer's Avatar
ricer
Well I switched my intake pipe over to pvc tonight so I wouldn't have any concerns with heat saturation, so I think I should be good to go now. Thanks for the heat saturation tip.
