Train/Air horn push button suggestions
Old Mar 11, 2011 | 08:46 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by pitbull24
weed, I was planning on wiring into stock horn, but I'm thinking I may want to keep them separate. But I also want this thing to scream if the alarm goes off, so I'll figure it out.
Then add a double rocker switch so you can flip between then OEM horn and air horn.
Old Mar 11, 2011 | 04:08 PM
Gasturbine's Avatar
Gasturbine
I run mine with a foot switch from a RV toilet, mounted to the left of the brake pedal. I had it tapped in to the regular horn, but found out right away folks didnt appreciate the "toot" when I set the alarm.
I find it works great, and after I got used to it, I can do a panic "honk" just as fast as the steering wheel button.
Old Mar 11, 2011 | 06:33 PM
Travelin man's Avatar
Travelin man
I got a momentary switch from Radio Shack and fabed a bracket out of sheet metal and mounted it on the floor under the E brake . Can't see it unless you bend down to look under the dash .
