Truxxx Level Kit
Old Mar 14, 2011 | 03:58 PM
Razorhawg's Avatar
Razorhawg
Default Truxxx Level Kit
Well now is the time to buy my level kit (airbagit spindles are out cant really find great info on them and seem sketchy with factory 17" wheels but i can always add those later if they turn out to be legit) did some hardcore searching and found the truxxx level kit at tire rack for $111. the one main thing that stands out to me about this kitl is its steel instead of the poly that fat bobs or daystar uses which means no settling. but another thing that i noticed that was different is the design of the kit itself. ive read on this forum that the actual level is about 1-3/4" of lift and a total size of 3" meaning that i could use the stock rubber isolator that is roughly 1/2" (which would do away with the metal on metal contact that cloud was having when he installed his last year matt99 you might remember that) im guessing ill get a lift of 2-1/4" which will probably be perfect to keep it from hitting the spring bucket because the readylift kit is a 2-1/4" kit and they said they havent had any problems with spring bucket contact
that being said im wondering if anyone has any experiences lately with the truxxx kit how well does it hold up and if you are happy with the kit itself
heres a few links that ive found about the kit itself so others can read about it and the installation
http://www.truxxx.com/product/dodge/...1-2WD-Ram-1500
http://www.truxxx.com/pdf/604080.pdf
and for reference about the readylift kit
http://www.readylift.com/c-231-dodge...-only-225.aspx
