100watt Hellas
Old Mar 17, 2011 | 03:22 PM
JDG103's Avatar
JDG103
Old Mar 17, 2011 | 08:10 PM
BigHorn777's Avatar
BigHorn777
If you are running 100watt bulbs and you installed your kit with the wire supplied you should go down a size in wire, meaning bigger wire. Here is a guide that will help you decide what you'd like to do to prevent a premature melt down. http://www.bcae1.com/wire.htm . I can only suggest to you that you should use 12awg wire, and rewire the entire thing to protect your truck. As far as fuse, well the lower amp you use the easier it will be to blow, using 2 100watt bulbs and 12awg wire you should use a 20 watt fuse or smaller no larger.
Old Mar 17, 2011 | 10:13 PM
dodge1hemi00's Avatar
dodge1hemi00
Ok thanks
Old Mar 18, 2011 | 08:22 AM
Boo Radley's Avatar
Boo Radley
the posts in the faq section are spot on about light wiring. i know a lot of guys who run higher wattage lights than what the wiring is rated for and almost none have a problem but then every once in a while you hear about that one guy who had his truck burn to the ground. it's just good insurance to use proper wiring.
https://dodgeforum.com/forum/3rd-gen...nd-relays.html
https://dodgeforum.com/forum/3rd-gen...ll-lights.html
Old Mar 18, 2011 | 08:44 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You should have done a night time before and after picture.....LOL
Old Mar 18, 2011 | 11:22 AM
dodge1hemi00
Thanks or the links
And weed maybe I'll do a pic tonight its real easy to take the bulbs out
