Tire pressure question....
Old Mar 20, 2011 | 01:07 PM
bigdaddyII's Avatar
bigdaddyII
Its an A/T tire. The only other tire i have ever seen with a 35 psi max is Fords OEM Hankooks.
Old Mar 20, 2011 | 03:08 PM
HammerZ71's Avatar
HammerZ71
I was actually a little surprised when I got my Terra Grapples for my Grand Cherokee. All the guys I know with them on trucks have like 50 PSI max on theirs, but then again, they have the truck models and not the passenger car model like I put on my Grand Cherokee.
If I'm not mistaken, the P-rated Toyo Open Country A/Ts are 35 PSI also...
Old Mar 20, 2011 | 03:51 PM
bigdaddyII's Avatar
bigdaddyII
I was surprised as well. I felt lost, not knowing what to do lol. I emailed Nitto about it and will see what they have to say. Also when I stopped for gas last night after traveling approx 100 miles, I felt the tread of the tire and it was quite warm. I dont know if this is normal or not as I have never went around feeling the tread on tires before, for now I am just assuming the extra heat due to the tires breaking in. I ran the at 35 psi cold (actually 75 degrees at the time), and they seemed to handle the 520 miles up here without any problems.
As an odd side note, I looked at the door jamb sticker on my truck and the tire size listed there is P245/70/17 and on my build sheet it says the truck came with P265/70/17, which is what was on it when I bought it. Weird.......
Old Mar 20, 2011 | 05:54 PM
HammerZ71's Avatar
HammerZ71
Personally, I'd only really go by the door sticker if I had a comparable tire to stock. Same size, ply and load rating.
I have "D" load, 35" tires on my truck that have a max of 50 PSI and if I ran them at the 35 PSI that the sticker says they would handle like sh*t, get **** poor mileage and not last worth a lick. Imagine if I put "E" tires on it with a max of 80 PSI.
Old Mar 20, 2011 | 10:34 PM
bigdaddyII's Avatar
bigdaddyII
On a previous truck I had D range A/T KOs, and the max on those was 65 psi. Wonder what Nitto is doing to be able to obtain similar load rating with lower PSI.
Old Mar 20, 2011 | 10:55 PM
HammerZ71's Avatar
HammerZ71
The tires on my truck are Cepeks, all Cepek and Mickey Thompson "D" tires are 50 PSI. Higher ply rating than A/T KO's. Thicker carcass means less air needed...
Old Mar 20, 2011 | 11:42 PM
bigdaddyII's Avatar
bigdaddyII
Ah okay. I knew that you had Cepeks too, just not thinking too clearly here lately.
Old Mar 23, 2011 | 11:01 AM
bigdaddyII's Avatar
bigdaddyII
Okay, I just got off the phone with Nitto, and they assure me that the tire will be fine running at its max psi (35) because thats the door sticker recommended. In a way I knew he would resort back to that, but did tell me that if I were to run D or E rated tires the proper inflation for normal driving (not loaded) would be 45 psi. I will run these at 35 psi and moniter wear, as I am more concerned with tire failure from too little air then too much.
