Royal Purple friction modifier?
Old May 3, 2011 | 12:08 PM
1987notchback's Avatar
1987notchback
Default Royal Purple friction modifier?
so i decided to use royal purple for my rear diff service. royal purple says it has friction modifier in it? do i need to still add a seperate friction modifier? thanks mike
Old May 3, 2011 | 01:12 PM
drewactual's Avatar
drewactual
I hope the answer to this is NO.. because I did my diff's with royal purple too..
Old May 3, 2011 | 01:15 PM
Matt99's Avatar
Matt99
I put the RP in and still used a friction modifier.
Old May 3, 2011 | 02:17 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can but it is not necessary.
Old May 3, 2011 | 03:26 PM
HammerZ71's Avatar
HammerZ71
I would NOT put an additional friction modifier in with the RP, unless it started to chatter on you, then I'd add it in half bottle increments to see if shuts up...
Old May 4, 2011 | 01:41 AM
1987notchback
it does not chatter, but does groan once in awhile when starting from a stop.
Old May 4, 2011 | 11:08 AM
1987notchback
oh random, usually tends to do this when it is colder.
