tire wear problem
Old May 18, 2011 | 11:55 AM
I_am_tcrow's Avatar
I_am_tcrow
Default tire wear problem
i was wondering if anyone might be able to give me any insight into what might be causing both of my front tires to wear faster on the inside than the rest of the tire(s). any info would be helpful.
Old May 18, 2011 | 03:51 PM
MikeHTally's Avatar
MikeHTally
Toe-in or camber need to be adjusted. Time for an alignment.
Old May 18, 2011 | 04:26 PM
HammerZ71's Avatar
HammerZ71
When an inner rib wears faster than than the rest of the tire, the need for wheel alignment is indicated. There is excessive camber causing the wheel to lean too much to the outside and putting too much load on the inside of the tire. Generally this calls for an alignment, as Mike stated, but misalignment could be due to sagging springs, worn ball joints, or worn control arm bushings as well.
Old May 18, 2011 | 07:00 PM
I_am_tcrow's Avatar
I_am_tcrow
thanks guys just got done getting it aligned and all seems to be well
Old May 19, 2011 | 12:21 AM
Marklorenzo's Avatar
Marklorenzo
Yep, Alignment and Ball Joints and bushing seem to be the determining factor from what I notice on most vehicles.
