Towing Capacity
Old Sep 7, 2011 | 09:23 PM
crmfghtr's Avatar
crmfghtr
Default Towing Capacity
Hi Everyone,
I'm new to this site so if i'm posting in the wrong place please forgive me. I own a 2008 Dodge Ram 2500 SLT Mega Cab 4x4 w/6.7 cummings, 373 rear gears. I also Added 3500 Rear leaf springs. I'm thinking of purchasing a 5th wheel and I need to know what this truck can tow comfortably. How much pin weight can it support ? A 5th wheel that has a dry weight of 12,400 lbs I figure loaded maybe at 14,600 lbs. Will this strain the truck too much? is it safe to say, the truck can pull this ok?
Thanks,
Robert
Old Sep 7, 2011 | 10:26 PM
Owensue's Avatar
Owensue
You can check here... http://www.dodge.com/towing/D/vehicle_to_weight.jsp?
I would select the 3500 because as you can tell by selecting a vehicle by model, the images appear to be in the wrong order. The 2500 should be the 1500 the 1500 should have the 4500 graphic.
I had another look, that page is messed up bad for 2008.
Old Sep 7, 2011 | 10:47 PM
Owensue's Avatar
Owensue
I did some searching for you and found this... http://www.dodge.com/bodybuilder/200...r/mlup2500.pdf
Old Sep 8, 2011 | 10:17 AM
BadHazard's Avatar
BadHazard
You'll be fine, you can pull that all day long and then some. And its a Cummins. No G
