good bolt on?
Old Nov 23, 2011 | 11:47 PM
truckin151's Avatar
truckin151
I believe the stock intake manifold opening is only 85mm maybe 86mm, and the stock TB is around 83mm, so IMO the 90mm would prove pointless there as you would be blocking some of the air flow. A larger an 85mm tapered would work good (had one on mine), or an 84mm straight bore would probabbly wor good.
