Front End Rebuild
Old Nov 26, 2011 | 08:23 AM
1987notchback's Avatar
1987notchback
Default Front End Rebuild
hey guys about to do some front end work. my steering rack is leaking pretty bad has been for awhile. figured i am going to replace it before it gets cold. also i am going to replace the lower balljoint and upper control arms. the front end is getting sloppy and the truck has 82,000 on it. any other parts i should replace while i am doing the other parts? thanks mike
Old Nov 26, 2011 | 09:48 AM
bigdaddyII's Avatar
bigdaddyII
Might as well change the outer tie rod ends too while you're replacing everything else.
Old Apr 18, 2012 | 04:34 AM
1987notchback
i know this is an older post. still have not done my front end but am going to soon. the question i have which i think i know the answer to is when i do my upper and lower ball joints i will not need a front end alignment afterwards? i would just need one after i do the rack and pinion? thanks mike
