Window Haze
Old Dec 23, 2011 | 09:11 PM
CaliDodgeRam's Avatar
CaliDodgeRam
Default Window Haze
Since I've had the truck, 09, I've noticed an ugly haze on both the front windows only visible from the outside though. Thought it was the tint, had it removed and replaced, didn't help. In our house we had the same problem, but that was because the windows were double pained. Any idea on what would cause this in the truck? Thanks
Old Dec 24, 2011 | 09:18 AM
ricer's Avatar
ricer
It wouldn't be any type of overspray would it? You can spray your window with good glass cleaner, I mean completely soak it, and then use a BRAND NEW razor blade to see if the blade shaves whatever film is on there off. You have to use a new single edge blade and if it does take the film off keep switching to a new blade like 4 or 5 blades to a window. And make sure you keep a good coat of glass cleaner on the window where you are using the blade or it will scratch the glass. When I worked for a mobile glass shop we did alot of work for body shops and that was how we got all kinds of stuff off of glass when we had to reinstall glass we had taken out so they could do the body work.
Old Dec 25, 2011 | 05:34 PM
CaliDodgeRam
Thanks man shoot it's worth a try...never even thought of that I have a buddy who owns a body shop I'll have to ask him as well!
