where to buy
Old Dec 25, 2011 | 09:50 PM
SpecialEdJon's Avatar
SpecialEdJon
Default where to buy
Im looking to buy the 3" RC Lift and some HIds. Is there a good place to buy them both at? I also might get a few other things while im at it but whats a good play to buy everything at once at besides ebay.
Old Dec 25, 2011 | 11:46 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
best and cheapest place for 3 inch spindles is ebay for about 270 i think last i checked. You can also find them on www.airbagit.com. Check out our dedicated HID thread as it WILL save you some time. Our sponsor www.hidxtra.com has a vendor section here and does right by our members
https://dodgeforum.com/forum/vendor-...ecial-buys-43/
Old Dec 26, 2011 | 12:51 AM
SpecialEdJon
im doing the full 3" lift not the spindles and ima go with the hidaxtras do i need to get the relay and Cancellor? O yeah and i need the 9007 buld right
Old Dec 26, 2011 | 01:13 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
when you say a full 3 inch lift do you mean front and back? If so them just get the spindles and some 3 inch shackles or blocks.
Yeah, 05s have 907 head lights and 9006 fogs
Old Dec 26, 2011 | 01:16 AM
SpecialEdJon
yeah i was gana get the full kit that comes with front springs and shock and rear shocks and blocks because i dont have alot of money to spend on a lift + new shocks and springs. Im using the money i got from x-mess to.
Old Dec 26, 2011 | 01:24 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Gotcha.....a budget lift. Been there and done that one
First thing ill throw out is a body lift from Performance Accessories. It s a 3 inch and runs 300 to 350
next thing are these CST 3 inch springs for 180
http://www.performancelifts.com/cgi-...rt/CSCDX2.html
You can run them with $5 shock extenders from autozone and the blocks or shackles shouldnt cost more than 50.
Dont HAVE to run extended shocks on the rear because there isnt as much weight as there is on the front. However, if you want new shocks on the front and rear then look at some Comp ES5000's
Old Dec 26, 2011 | 01:39 AM
SpecialEdJon
i was thinking of doing the body lift but i dont want to get into the whole bumper crap lol. I feel if im gana spend 180ish on just the springs im better off at spending 120 more and geting everything i need. This isnt gana be used for anything just looks and DD
Old Dec 26, 2011 | 09:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I gotcha. I did a body lift on mine and it wasnt hard at all. Only the front bumper needed trimming as the back bumper came with brackets. A sawzall made quick work of the front.
Either way, hope this is all enough to get you going, if you do the suspension lift, check and replace anything else kn the front end like ball joints, tie rods, ect and dont forget the alignment.
Old Dec 26, 2011 | 01:01 PM
SpecialEdJon
thanks weed and do i need to get the Cancellor or relay from extrahids?
Old Dec 26, 2011 | 01:29 PM
08HEMI1500's Avatar
08HEMI1500
If they don't provide them. Yes
