Q about my build sheet
Old Jan 15, 2012 | 04:26 PM
NoLimitzR1's Avatar
NoLimitzR1
Default Q about my build sheet
Ok I've got my build sheet. Still trying to figure out a few things.
For one is the AGG sport group the sport package? And is XFUS the towing package. Trying to debate if my truck can use the oem tow hooks as i don't have any but I do have the three holes in the bracket each side for the tow bar. Only thing is have to do is pull out the panel in bumper for hooks. Also I have a bumper mount hitch ball on thr back with the rear tow bar bracket, can I just bolt on the 2in reciever oem mount that's slightly under the bumper?
VIN 1D7HU16D75J650331 Vehicle Description DODGE RAM SLT 1500 REG. CAB PICKUP Model Year 2005 Body Model DR 6 H 61
Sales Code: --- Description: *V9 Cloth 40/20/40 Bench Seat -DV Dark Slate Gray AGG Sport Group APAS Monotone Paint A85P 5.7L ENG (EZA)/5SPD A/T 5-45RFE(DGQ) BAZS 136 Amp Alternator BCES 600 Amp Maintenance Free Battery BRRS 4 Wheel Disc Rr Anti-Lock Brakes CBEP 40/20/40 Split Bench Seat CGDS Front Height Adjust Shoulder Belts CGZS Passenger Air Bag On/Off Switch CG1S Next Gen Multistage Front Air Bags** CKES Front Seat Area Carpet CLAS Front Floor Mats CSPS Passenger Assist Handle CUSS Overhead Console w/Trip Computer CU3S Behind the Seat Storage / Bin DGQ 5-Spd Automatic 545RFE Transmission DHAP Lock-Up Torque Converter DHES Man Shift-on-the-Fly Transfer Case DJMS 205MM HD Front Axle DMH 3.92 Rear Axle Ratio DRBS Corporate 9.25 LD Rear Axle EAGC All Gas Engine EZA 5.7L V8 HEMI Engine GACS Tinted Glass Windows GJDS Rear Fixed Window GNAS Rear View Day/Night Mirror GNMS Passenger Side Sun Visor w/Mirror GTSS Power Heated Mirrors, Fold-Away GVBC All Vehicles W/Power Mirrors GXMS Remote Keyless Entry HAAS Air Conditioning HGBS Dash Liner Insulation HGFS Floor Tunnel Insulation I60S Route 60 - CSX, Westboro, MA JAYS Instrument Cluster w/Tach JCBS 120 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers JJAS Cigar Lighter JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet JPBS Power Locks JPDS Power Windows, Driver One-Touch K4SP STRIPE/BADGE/MOLDING/COLOR LBCS Glove Box Lamp LMAS Halogen Headlamps LNJP Fog Lamps LPES Cargo Lamp MBPP Body Color Front Bumper MBQP Body Color Rear Bumper w/Step Pads MDAS Front License Plate Bracket MFNP Body Color Grille MGAS Ram's Head Badge MTDS SLT Badge MUSS 4X4 Badge MWDS Removable Tailgate w/Caliper Latches MXBS Front Air Dam MXCS Front Bumper Sight Shields NAS 50 State Emissions NBEP U.S. Emissions w/OBD 1 NBKP EVAP Control System NFWS 26 Gallon Fuel Tank NHBP Auxiliary Transmission Oil Cooler NHMS Speed Control NHNP Electronically Controlled Throttle NZDP Next Generation Engine Controller PS2A Bright Silver Metallic Clear Coat QS2S Bright Silver Metallic Clear Coat RBKS AM/FM Compact Disc Radio w/Chgr Ctrl RCDS 4 Speakers RDDP Fixed Long Mast Antenna SBAS Power Rack and Pinion Steering SCFS 4-Spoke Steering Wheel SFBS Front Heavy Duty Shock Absorbers SGBS Rear Heavy Duty Shock Absorbers SHAS Front Stabilizer Bar SUAS Tilt Steering Column TBBS Full Size Spare Tire TBMS Tire Carrier Winch TTJP P275/60R20 BSW All Season Tires TZAP Goodyear Brand Tires WF3 20X9.0 Aluminum Polished Wheels WGAP 20" Steel Spare Wheel WLZC All Aluminum Wheels WMJP Center Hub XA8S Non Adjustable Pedals XBSS Pickup Box XFUS Trailer Tow w/4-Pin Connector Wiring YAAS Build To U.S. Mkt. Specifications 5I4S Four Wheel Drive (4WD)/(4X4) 5ZES 6 FT. Cargo Box 5ZJS Regular Cab 5ZLS 1500 Series 5ZWS DR-Vehicle Family
Old Jan 15, 2012 | 04:44 PM
HammerZ71's Avatar
HammerZ71
I'm pretty sure the XFUS is just the 4 pin trailer connector, with no factory frame mounted hitch you don't have factory tow.
The AGG sport package denotes color match painted bumper and grill...
Old Jan 15, 2012 | 04:48 PM
MikeHTally's Avatar
MikeHTally
Well, tow hooks have nothing to do with a tow package. If you already have the hitch receiver, there is nothing more to bolt on. No hitch receiver, no tow package. Is the grille frame painted body color? If so, I believe that's the sport package.
Old Jan 16, 2012 | 08:31 PM
NoLimitzR1's Avatar
NoLimitzR1
I'll post a few pics, so Hammer I have factory matched paint but no sport package then correct? So I shouldn't have to worry about a installing a tow hook plate, I know they say that sport package has different mounts.
And with my rear hitch the hitch goes through the number then underneath it bolts through a plate and bar, the bar goes to the frame of truck, but there is no reciver for using various attachments. I want to get the oem reciever so i can use various 2inch items, I.e hitch, bike rack etc
Old Jan 16, 2012 | 10:53 PM
MikeHTally's Avatar
MikeHTally
No receiver, no tow package. Most any truck accessory shop can install a frame-mounted receiver hitch. Trailer vendors can, too. From what I've read U-Haul has some issues with this task, but I've not been there in a long, long time.
Old Jan 17, 2012 | 05:16 AM
NoLimitzR1's Avatar
NoLimitzR1
But there's a bar. I dunno if its a uhaul bar or what it appears oem the bar runs under bumper and where the hole is lines up to bumpers hole for where the hitch goes through. I tried looking at parts manual from weedahoe and bat could be oem. Once its done snowing ill get a few pics for guys to look at.
Actually let's say thee reciever was removed from the tow bar is there any larger hole in the bar at all that lines up with center of bumper? Wonder if bar was added and uhaul added their hitch to run it in that form I have few dings I can safely say that this was put on by previous owner.
