2007 dodge ram cst 7'' lift
Old Mar 1, 2012 | 09:08 AM
ramin44s's Avatar
ramin44s
Originally Posted by Brandon Anderson
Assuming you have a 4x2 if you used coil springs? How did you get 3" coil springs to work without whacking the **** out of your UCA when you hit bumps? Any more than 3" lift between control arms, and your UCA will be lodged firmly against your upper coil bucket.
It's a cst 7" lift it's a kit that includes 4" spindles with 3" coils and no I don't hit anything and it rides good
Old Mar 1, 2012 | 10:42 AM
Brandon Anderson's Avatar
Brandon Anderson
Reason I ask, is because there have been people here who did a lot of testing on the '06-08 4x2 front suspension, and they found that using a 2" spacer on stock springs causes the UCA to hit the coil bucket during periods of extreme suspension travel. A 2.5" spacer causes the UCA to slam the coil bucket pretty hard, even over speed bumps and potholes. So I was surprised that a 3" longer coil did not cause the same thing on yours. This is good news for me.
Old Mar 27, 2012 | 05:03 AM
Brandon Anderson
Originally Posted by Kustomblack1
When I lifted my truck with the 7" CST lift kit I was surprised to find the new coils are not taller than the stock coils but only had extra coil, they are the same height has the stock coils except they are stiffer. I think it rides and feels better than stock. I had this lift on for months now and its great.
So you're saying they are the same free height as stock coils, but they provide lift by sagging less? That makes sense, but less sag would still mean the UCA gets closer to the coil bucket.
Welcome to the forum BTW.
Old Mar 27, 2012 | 10:30 AM
ramin44s's Avatar
ramin44s
I love my cst lift to rides good and I've never hit anything or rubbed anything with this set up
Old Mar 27, 2012 | 05:24 PM
Brandon Anderson
That is all really great news, as long as I can purchase just the CST coils LoL
I've been looking into swapping in coils from a 2500 CTD, but haven't been able to find all of the specs I need to make sure they will fit and do what I want them to. I'm looking to really stiffen up the suspension, and it sounds like the CST coils are it.
Old Mar 27, 2012 | 10:57 PM
Brandon Anderson
Seeing the pics, it all makes sense now. The 3" lift spindles I installed are the same height and angle as the stock spindles, but lift is achieved by moving the hub mount down. Unlike the spindles I installed, the CST spindles are longer and angled differently, allowing for more room between the upper and lower arm. This lets the UCA sit at nearly its normal position even though the spring is lifting the truck. My 3" spindle, with those CST springs, would likely provide the same amount of lift, but would still cause the damned UCA to contact the coil bucket. I love my '08, I really do, but the UCA on the '02-05 1500 was better for lifting, IMO.
Old Mar 28, 2012 | 07:41 AM
ff2011's Avatar
ff2011
If anybody has questions about the 2006-2008 dodge ram 2wd CST lift, I will be happy to help. If you are the DIY guy I can post any pics you need. I put the entire lift on myself in about 6 hours and the only thing I did not do was the alignment, you will have a positive camber after the lift. You will not need a camber kit. cost me $129 at Goodyear to fix camber.
Thanks for the info on here I also have a 2wd 2007 and I am looking for the best lift and after seeing this it looks like the right one thanks so the lift was pretty easy to install any special tools any thing with the balljoints or tierods
Old Mar 28, 2012 | 07:43 AM
ff2011's Avatar
ff2011
Thanks for the comments, the truck is riding pretty good dont really want to mess that up but really want another inch up front because it seems like the front settled more than I planned, I'll check out hell bent steel also
Your truck looks great man
Old Mar 29, 2012 | 05:24 PM
ff2011's Avatar
ff2011
Kustom Thanks for the info think I am going with the one you have now is it 4 inch spindle in front and coils what did you do in the rear or is it a strait 7 all around and can I see a pic of your truck and where did you buy the lift thanks
Old Mar 30, 2012 | 09:57 AM
ff2011's Avatar
ff2011
Kustom thanks for the info man your truck looks bad a%% excatly how I want mine thats what Im gonna get thank you
