Adjusting Tire Size using programmer
Is anyone familiar with adjusting the tire size setting with a programmer?
My 2003 dodge ram 1500 currently has 33 inch tires while the stock tires were about 30.75 inches. I have a Banks AutoMind programmer, and I am having difficulty in adjusting this setting. I was hoping somebody might be familiar with this task.
In my situation, I went through the process of adjusting the setting from 30.75 to 33 inches, and when the programmer attempted to adjust the speedometer, the process failed. I was given an error message saying "Cannot adjust tire height. No abs module present in vehicle."
I currently don't have any warning lights on the dashboard, so I'm not sure if it's the programmer or perhaps something with the truck, such as a fuse.
Does anyone have any suggestions?
Thanks!
Thanks!
Apparently there is a range limit in the adjustment. Folks have had to fiddle with the settings to get the actual speed to align with the indicated. My 285/70s cause my speedometer to be 4.3% low. I just live with it. Easy enough to know that an indicated 76 is 80. The mph error is less at lower speeds.
Thanks!
Thanks!
I've got a 2004 Ram Hemi in my Dakota and I can't even get to the point of entering the tire size. In the Predator Quick Adjust section as soon as I click on tire size I get the message "Error reading tire size parameter".
I just got done trying to correct my tire TODAY and am frustrated it doesn't work. So the speedo is off and can't be corrected.
