33inch tire question
Old May 13, 2012 | 10:30 PM
atv1988's Avatar
atv1988
Be ready to never have a clean truck again thought thats the only issue I had
Old May 16, 2012 | 03:40 PM
e1diab1o's Avatar
e1diab1o
I've got the 33x12.50x17 General Grabbers and have been looking for rims, but can't find a set that I like and the ones I do like don't fit. I really like the Dick Cepek Torques, but does anyone know if 5" backspacing is enough to run this tire? and they have a +6mm offset, idk if that will have a huge impact or not.
Old May 16, 2012 | 06:12 PM
gHEMImorePower's Avatar
gHEMImorePower
I run 33's and these tires make no change to anything. 35's are when you really need to worry about gears and all that stuff.
Old May 16, 2012 | 06:13 PM
gHEMImorePower
However mine aren't 12.5 wide not sure how much difference that'll make
Old May 16, 2012 | 06:19 PM
HammerZ71's Avatar
HammerZ71
Positive offset and 12.5" wide tires won't fit on the coil-over front ('06+) 4x4s, but the torsion fronts have a bit more room, you should be OK with the Torques, but it'll be tight...
Old May 16, 2012 | 07:57 PM
gHEMImorePower
I've seen torques with negative offset. The dc-II (what I'm getting) have negative offset
Old Jun 14, 2012 | 09:48 AM
e1diab1o's Avatar
e1diab1o
Well, rims were back ordered for while and ran into a few other problems, but I finally got one on for a test fit yesterday. It fits perfectly and looks great! thanks for your input guys.
Old Jun 14, 2012 | 01:48 PM
Five.SevenRAM's Avatar
Five.SevenRAM
i wish i had 3.92's...i only have 3.55's...at least thats what my build sheet says. 33's are pretty much it for me. your truck looks good with that tire/rim combo man!
Old Jun 14, 2012 | 05:32 PM
08HEMI1500's Avatar
08HEMI1500
Damn! Grabbers might be my next tires when I finally switch to 17s. Those look purdy
Old Jun 14, 2012 | 07:12 PM
HammerZ71's Avatar
HammerZ71
I'm probably gonna get Mickey Baja Claws as my next tires, which won't be for some time, my almost six year old Cepek FCIIs are only showing very minimal wear. But I'd be tempted to go with the Grabbers, those red letters would look badass on a red truck!!!
