Homebrew CAI and few other minor mods
Old Sep 11, 2013 | 01:10 PM
  #111
Jmn822000's Avatar
Jmn822000
Originally Posted by Old man with a Hemi2
I may be missing something here, but how is a license plate gonna protect the ac hose any better than the pvc touching it. Last time I looked PVC was very smooth, much smoother than that plate, so I see no protection from the plate at all, unless there is a junction under the plate that has a sharp edge
The edges of the plate are behind the pipe not underneath.
Old Sep 12, 2013 | 09:56 AM
  #112
Old man with a Hemi2's Avatar
Not talking about the edges of the plate, wondering if there is a pvc junction being covered by the plate. If not the plate is useless, because the pvc is smoother than the plate. the plate would only be of any benefit if it was protecting the ac hose from the sharp edge of a pvc junction
Old Sep 12, 2013 | 07:40 PM
  #113
Jmn822000's Avatar
Jmn822000
I didn't want the paint on the pvc to rub off from contact with the hose.
Old Jan 10, 2014 | 02:09 PM
  #114
BlackHemiSport's Avatar
BlackHemiSport
The 4 inch K&N cone filter that I got form AutoZone was too big. It was wedged up against the housing of the original airbox at a bad angle. I need a 4 inch filter that is a little shorter in length/height. Can someone reply with a 4inch K&N part number that fits?
Old Jan 10, 2014 | 11:14 PM
  #115
itsUhHemi's Avatar
itsUhHemi
You have to remove the old housing.
Old Jan 11, 2014 | 10:05 AM
  #116
ewing111's Avatar
ewing111
Yeah I completely removed the old airbox
Old Jan 11, 2014 | 10:16 AM
  #117
BlackHemiSport
How do you remove the lower part of the airbox housing. I removed the two bolts that fasten it to the inner wheel well but it won't budge. I see two grommets, not sure if they are holding it in but maybe I need to force it out.
Old Jan 11, 2014 | 10:38 AM
  #118
BlackHemiSport
Just to be clear I'm talking about the piece that the housing slides on to. It has two posts that stick up.
Old Jan 12, 2014 | 07:43 AM
  #119
ewing111's Avatar
ewing111
I'm pretty sure it just pulls off of those, it's been a while since I took mine out, I will try to take a look today and let you know.
Old Jan 12, 2014 | 10:41 AM
  #120
BlackHemiSport
I'm not talking about the airbox itself I have that out. Its the mount that the air box slides on to. This is a picture of what I'm talking about.
http://image.truckinweb.com/f/tech/1...nt-removed.jpg
