USB hardwire cable.........
I'm thinking I might hardwire a mini USB connector cable for my Tom Tom XL to the fusebox.I know they sell a cable that breaks down the voltage from 12v to 5v.I was just wondering if anyone here has done this and would you recommend it.
You have a cigarette lighter cable, right? Just get a cigarette lighter cord splitter from Radio Shack/Harbor Freight, etc. Cut the female connector off the splitter, put a 2A fuse in one side and wire it to the back side of the lighter. Plug your GPS's power cable into the newly-installed connector.
I had a cig lighter but I used the power and ground wire too power a SPST rocker switch for footwell lights.I have an accessory outlet which I currently use for the GPS but I want to clean things up a little.I don't want too see the wire running down my dash and behind things then sticking out from my drop down door under my steering column.Thats why I want to hard wire to the fuse box.
What I'm thinkin about doing is using a mini USB hard wire GPS cable.You can hook it into your fuse box with an "add a fuse"(?) It will break down 12v to 5v.You can run the wire thru your fire wall into the cab and then plug the USB cable into your GPS.Amazon sells the cable for 14 bucks.The fuse jumper is probably 3 or 4.I would use the fuse jumper in a slot that is key-on only.I was just wondering if anyone here has ever tried this kind of set up and if so,with what success.
