Should I replace my fuel lines when I replace my fuel pump?
My fuel pump is starting to go and will need replaced rather soon. I was wondering if I should replace anything else while I'm at it such as the fuel lines. Also I plan on just using what ever fuel pump they have at the auto parts store but was wondering if you guys had any thoughts on brands I should stay away from or brands that you would recommend?
FYI my truck has around 110k on it. Not sure if that has any bearing on replacing the fuel lines or not.
110k is pretty young to need a fuel pump. No one has mentioned replacing fuel lines. That would seem unnecessary. Rock Auto has 'em from $135-$264. Make sure you get the one for the right tank size - the sender might be different.
