Got my truck back from the shop with my truetrac installed, couldnt be happier
Old May 21, 2013 | 05:52 PM
DirtyDodge812's Avatar
DirtyDodge812
Default Got my truck back from the shop with my truetrac installed, couldnt be happier
I just got home from picking up my truck and a little test drive. I got all new bearings and seals in the rear axle and a truetrac installed. The shop was very affordable and Ive heard nothing but good things about them so I will probably go back to them when I redo my front differential. I put about 20 easy miles on the bearings and kept the speeds low. I stopped into a park on the way home and put a tire on the grass and other on the pavement and with a little gas it spun both easily. After seeing it work there I had to try a donut so I went to an empty parking and sure enough it spun both tires and the rear end kicked right out. Im gonna keep the donuts to a minimum but its nice to know how well the truetrac worked. Im glad I chose it over the auburn lsd.
Old May 21, 2013 | 11:05 PM
ewing111's Avatar
ewing111
why glad over the auburn? Something about that that you think wouldn't have worked as well? I've always heard mostly good things about the auburns.
Old May 22, 2013 | 06:23 AM
DirtyDodge812
I've heard a lot of good things about the auburns but a few horror stories as well and a lot of people who said that they wore it out prematurely. Im not very easy on my truck so I wanted a carrier that Im sure can take the abuse.
