Front Driveshaft
Old Jul 3, 2013 | 01:56 PM
Greasy24's Avatar
Greasy24
Default Front Driveshaft
I have asked before but never recieved a answer. My front driveshaft is at a crazy angle from 6in lift and wore the seal out and slung grease every where. What can I do about the angle it will just break the seal again if I replace it and no one around here sells the part but ebay.
Old Jul 3, 2013 | 06:06 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I'm thinking a Slip Joint Eliminator might be the part you're looking for?
Old Jul 5, 2013 | 08:45 AM
Greasy24's Avatar
Greasy24
I looked up that joint eliminator and i don't think thats what i need, i think a front driveshaft with cardnal u-joints or how ever you spell it is what i need?
Old Jul 5, 2013 | 01:57 PM
dodge dude94
Double cardan joints I believe is what they are.
Old Jul 17, 2013 | 04:19 PM
Greasy24's Avatar
Greasy24
I found a kit and replaced the stock one for now, but i found a cv axle boot that should work as a good replacement untill i research further into it!
Old Sep 7, 2013 | 01:30 AM
Frieslander's Avatar
Frieslander
You can use axle wedges to shift the angle of the axle which will lessen the severity of the angle of u joint. you should then have it realigned.
