amplifier fitment
Old Aug 22, 2013 | 09:29 AM
furbyj1's Avatar
furbyj1
Default amplifier fitment
Hey guys, I'm currently in afghanistan and i need some help, so I've been doing some research as far as setting up a good sound system in my truck. I own a 2003 ram 1500 quad cab.
My only issue is I will be placing my amp under the drivers seat, but I dont know if it will fit..
I have the Pioneer GM-D9601 measurements: Width 13in x Length 8in
does anyone know if this will fit or the measurement under the drivers seat to mount an amp?
Old Aug 22, 2013 | 02:21 PM
KasperR34's Avatar
KasperR34
That should be able to fit. there is a lot of room
If not, you could mount it under the rear seat, whether that be on the floor or to the seat itself. Also look into mounting it under your middle seat.
Also, thank you for your service brother, I'll be in boot in 2 weeks 4 days
Old Aug 22, 2013 | 11:56 PM
furbyj1's Avatar
furbyj1
Thank you for the support!
as far as mounting the amp, I can only mount it under the drivers seat due to space. I just need measurements of what size amp can fit under the drivers seat
Old Aug 23, 2013 | 02:08 AM
KasperR34's Avatar
KasperR34
What is your branch/MOS? I'm going in as a Marine Security/Infantry
Are you sure you can't mount under the middle front seat?
Old Aug 23, 2013 | 11:07 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I mounted my amps behind my rear seat on the back wall
