Crank and no start... help!
Old Dec 9, 2020 | 06:01 PM
Ryen358's Avatar
Ryen358
Default Crank and no start... help!
I recently did some work to my 2003 5.9l magnum. I forgot to put the lower radiator hose clamp back on. The truck started and after it warmed up it started to spray water. The hose did not come off. I turned the engine off to put their clamp back. the engine did not start backup. I have changed the ignition coil and crankshaft sensor. Any help is very much appreciated.
Old Dec 9, 2020 | 06:08 PM
Alex Medeiros's Avatar
Alex Medeiros
Need more specifics. What work did you do to your truck prior to the issue occuring?
