Hi folks,
I'm planning to buy/install CB radio and antenna next summer. Could you please share your experience/pictures of setup ? I've found for 2nd gen but I'd like to see setup on 3rd gen. Thx.
Well I figured this would make a good first post as any, I have dual 4 foot Firestik antennas with a Cobra 18 WX ST II radio, works pretty good for my antennas not being tuned. Heres some pics (hope they work):
Tomorrow ill snap a few of where the radio is mounted. Hope this helps.
MGC 4.7
Looks very nice. I have a bed cover so such placement of antennas will not work for me but can you also picture how cable goes from cab to bed? Please... :-)
Ahh ok, well they do make offset mounts but they would show the coax cable hanging out then. The cable runs through the stakeholes and i brought it up through a drain plug in the back that i drilled a hole in and sealed it with silcone.
The plug is under the rear seat and just popped out with a flathead, I then ran the cable under the carpet and to the cup holder where I have it mounted:
Agree, nice setup.
MGC, did you break this plastic to put CB radio or it could be open easily? I didn't try but I'll try if you'll tell me that you didn't break this plastic :-). And big THX for pictures!
Thanks guys. Well taking the cupholder off was a pain, there were four screws and it still wouldn't come out so I yanked it out, which cracked some of the plastic backing yet most of the backing is useless. I ended up drilling holes in it and using a bracket to hold it in place. The only problem with the set up is I can't close the cupholder, but I can still use it.
That's sucks man. In 3rd gen there is much less space then in 2nd gen
